-   -   Rear end from a 71 Cutlass (http://www.hotrodders.com/forum/rear-end-71-cutlass-9467.html)
medicdogg 11-15-2002 04:32 PM
I have arear end out of a 71 Cutlass with the letter ID code of BO. I would like to know the ring gear size of this rear end.
Wmarden 11-17-2002 02:59 AM
Don't know for sure the answer but the following link might helps some. I did not see numbers for the 71, but they may be something there you can use.
<a href="http://www.442.com/oldsfaq/ofdif.htm#DIF%20Differential%20Codes" target="_blank">http://www.442.com/oldsfaq/ofdif.htm#DIF%20Differential%20Codes</a>
