Rear end from a 71 Cutlass - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2002, 03:32 PM
Cool Rear end from a 71 Cutlass
I have arear end out of a 71 Cutlass with the letter ID code of BO. I would like to know the ring gear size of this rear end.
Old 11-17-2002, 01:59 AM
Last journal entry: Some pics
Post
Don't know for sure the answer but the following link might helps some. I did not see numbers for the 71, but they may be something there you can use.
<a href="http://www.442.com/oldsfaq/ofdif.htm#DIF%20Differential%20Codes" target="_blank">http://www.442.com/oldsfaq/ofdif.htm#DIF%20Differential%20Codes</a>
