X2 on the above Info.
Add a Girdle type Diff cover and aftermarket rear Control Arms with Poly Bushings or Box your stock Lower Control Arms and install Poly bushings in the Upper & Lower Arms for more strength and wheel hop control. You can buy the inserts to box the LCA's or cut your own and weld in.
