rear end on 81 C-10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2011, 12:23 PM
rear end on 81 C-10
im lookin at changing rear ends in a 1981 C-10 would like a posi not sure whats better 10 bolt or 12 bolt??? another ? can a guy swap the internal shafts from a 4x4 to a 2wd? cause i found a 4x4 posi but i need the 5 bolt pattern not 6 so just wanerin if i can just pull out the 6 stud shafts and put in the 5 stud ones???????
Old 05-14-2011, 04:06 PM
SSedan64's Avatar
If the Axles are the same length & Spline count you can. I think 4X4 Axles are longer tho'.
Welding a rear brace on a ford 9 inch rear end makaveli200369 Transmission - Rearend 4 07-02-2009 11:19 AM
70's 12 bolt rear to replace 80's 8.5 rear MRGM Transmission - Rearend 4 02-07-2008 09:25 PM
1/2 tonn burb rear and 1/2 tonna blazer rear.. u joint? boneyard Buick Transmission - Rearend 1 10-09-2006 12:46 AM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 04:28 AM
67ssdiagram showing how the rear sway bar and control arms connect to frame and rear DeathByGreaser Transmission - Rearend 0 02-08-2003 09:10 PM
