rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2001, 08:32 AM
New Member
Question rear end
I'm putting a 74 olds cutlass together for weekend cruzing and the question is should i change to posi from a limted slip just to cruz or will it be wasted money, I'm going to change gears to 3.08 but do i really need a posi?
Old 12-22-2001, 09:29 AM
I weld things
Post
posi and limited slip are the same thing...
Old 12-22-2001, 04:25 PM
New Member
Post
it's the rear where when you raise the rear up and turn one wheel one way the other wheel turns the different direction.
