rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2002, 06:48 AM
Post rear end
who has the formula for figuring rear end ratio, tire diameter, rpm to speed. helping a friend put together a 40 chevy. he has found a unit out of a 79 cherokee he wants to use that is currently a 3.08. this will be a 350-350 combo and estimated weight of 3900#s, i think this gear is a little low. it will be used for trips to the lake and cruising, no drag racing. thanks , sj
Old 01-24-2002, 07:06 AM
Post
4lo.com this is the calculator I use... just put 1 for tranfer case, and everything still works great. (and will give you the overall ratio too)
Old 02-06-2002, 02:52 PM
Unhappy
Randy's Ring & Pinion and Richmondgear both have great calculators, just what you are looking for!
Old 02-06-2002, 03:01 PM
Unhappy
[ February 06, 2002: Message edited by: ODDA ]</p>
