rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2002, 08:28 PM
Post rear end
i an currently restoring a 67 camero and found the rear end carrier a disastor...the center pin was worn so bad that it snapped the retaining bolt in three. i ended up having to cut the spider gears and drive the pin half way out just to slide the axels. what a nightmare i had three full time mechanics look at this problem and they have never seen this before. well any way my questins is could i change this housing to a 8.5 ??
Old 11-12-2002, 08:48 PM
BOBCRMAN@aol.com's Avatar
Post
your mechs haven't been around long, that was a fairly common problem on those rears. put a 9" ford in it and end your miseries.
Old 11-15-2002, 03:32 PM
F-1Rodder's Avatar
Post
I agree, the damage you have is not uncommon, I bought a junk yard rear just to get the gears and had a similar problem.
Yes, you can get about any rear end you want in there, but do you need to? The 7 5/8" rears will handle close to 300hp in your car which if you are doing a pure restoration should be sufficient. With a spool or limited slip and a set of good slicks, you can break them too, but that combination was not availble from the factory. I do have a factory posi for that rear end sitting in my garage which I would sell to you for not much if your spline count is right. I was going to use it until I looked into what they will handle and found that my 450hp is a little out of its range.
If you need to have the bigger ring gear, then I would get hold of a 12 bolt and narrow it to what you need. You can do the narrowing at home with a welder, I can show you how. You buy the axles for $225 and you will have enough strength to handle a big block.
