Rear End Advice Needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2002, 05:59 PM
Post Rear End Advice Needed
Building a replica of a race I I enjoyed as a child (it was a 37 Chevy coupe; I'm working with a '38). The car I have is stock and all I have at rear is a housing and axles. I need to bolt up another assembly.
Given that I'll be running a tweaked 250 six, a three-speed transmission and will probably only drive this car from a trailer to a show area, (probably won't even bother with rear brakes), what's the consensus on what rear end I should bolt up. I'd like to keep the stock rear suspension.
Old 08-08-2002, 05:45 PM
Lou's Avatar
Lou Lou is offline
Last journal entry: some more body shots
Post
Hell look at the s-10 rear end it might be the same length as the stock one.
