Rear end angle?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2002, 05:32 PM
Question Rear end angle??
Installing a Ford 9" rear end in my frame. Had to cut off the original spring blocks so the factory setting are no longer there. So I need some suggestions on how to position the pinion angle. Is it a common angle or does it play in with the trans angle? Any suggestions will help Thanks! <img src="confused.gif" border="0">
Old 12-09-2002, 06:35 PM
46_stvblt's Avatar
Post
Yes, It does coincide with the trans angle. If the trans is 3 degrees down, the pinion should be 3 degrees up, or at least within 1- degree........GlennK
Old 12-09-2002, 08:58 PM
aka Duke of URL
Arrow
-Pinion Angle Theory-
Old 12-10-2002, 04:26 PM
Thumbs up
Thanks guys!! That will help out alot.
