Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear end axle seal leak
Old 09-26-2012, 03:32 PM
dilligaf's Avatar
dilligaf dilligaf is offline
I can't tell where exactly it is coming from due to having a emergency drum and shoes which keeps me from really getting a good look at it. I did notice when I first noticed the leak that where it was running down the inside of the tire that the oil/grease was causing some swelling of the rubber. Tells me that I have a synthetic in there. Maybe I should run this for a while and see if the seal swells from the grease. When I took it back apart the seal looked like it did when I first installed it.
