rear end bearings - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2007, 02:35 PM
FiveFeezy's Avatar
Fishing poles in the hot rod!
rear end bearings
Right now I have my rear end out of the car (1970 12 bolt) and I am planning on changing the wheel bearings. While I am at it should I change the differential bearings or should I wait until I have a posi unit installed and have them changed then? I don't want to get in over my head. Thanks for the help.
Old 03-29-2007, 08:14 PM
BOBCRMAN@aol.com's Avatar
If you are going to do rear end work in the near future. Then just change the wheel bearings. That way the new posi will have all new stuff.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
rear end / brakes, etc / INFO?? Pickup Guy Hotrodding Basics 7 08-02-2007 02:06 PM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 02:44 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 04:28 AM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 06:32 AM
