Rear end and big tires - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-17-2010, 10:19 AM
kleen56's Avatar
Lower gearing always helps with pulling power, but as Cobalt stated, will affect your highway driving by causing the engine rpm to be higher. I'd find out what gearing you actually have before guessing or planning to change gearing. You state the problem is lack of power at 35 mph. The gears may not make a big difference for you and you may want to look at helping the engine perform better. Headers and exhaust always make a big difference as does intake/ carburation. Your already running a Qjet carb which is a good carb so a good intake manifold might help. Have you done a compression check on the engine yet? If exhaust and intake is not enough, a camshaft (RV cam) change is another possibility along with dropping a Big Block in there (joking!). Your stock converter is fine. A stall converter will only help you launch off the line and not at 35 mph pulling something.
  #17 (permalink)
Old 11-17-2010, 10:45 AM
Mertz's Avatar
I already have ceramic headers and a performer intake with K&N top air cleaner. I haven't done a compression check but everything indicates that that shouldn't be a problem. It doesn't use any oil and it has a strong sound with the proflow mufflers and dual exhaust. Never has a starting problem even with the choke disconnected. Plugs and spiral core wires are new and shielded from header heat. It is fast above 50mph.
I also replaced the stamped rockers with roller tip to make sure I have equal length 1.5 rockers. I got new push rods to get the geometry right in the middle of the valve. They are adjusted with zreo lash than 1/2 turn if I remember right. If not 1/2 than 3/4. Ignition and timing are right on. I am using ported vacuum now instead of manifold because the new carb ran better that way. I can try going back to manifold.
  #18 (permalink)
Old 11-17-2010, 10:51 AM
kleen56's Avatar
I'm just curious why you lack power at the 35 mph range and not 50 and above? Maybe you have high gearing in the rearend and all your power is on top end. Then lower gears will definitely make a huge difference and wake up your low end pulling power. Now I'm curious what gearing is in there! LOL...
  #19 (permalink)
Old 11-17-2010, 11:47 AM
Mertz's Avatar
I will let you know as soon as I find out (this weeekend). I was having the 35 mph power problem when dailing in my Qjet. It has gotten somewhat better using Cliff's quad instead of mine but I don't think that is the problem.
  #20 (permalink)
Old 11-17-2010, 08:43 PM
fast68's Avatar
likes chevy trucks & boobies
410 or 457 were the most common ratios in the HO52 rear
the dana 60 rear that sometimes were under these trucks were mostly 4.10
but some were 4.57 or 4.56
and most were 4.10
can pull a house with these but horrible RPM on highway,.
will be screaming engine at 55 or 65
these were heavy strong workhorse trucks and not traveling trucks made for highway mileage
the sticker in the glovebox is called the SPID label and it should list the axle ratio
but not always does it
look for G codes
such as GT4 or GU6
there are axle related codes
i can give you full listing of axle ratios of both axles they put under these trucks if you really need, i have a red book for the trucks 72 older it lists every single RPO code, and ratio and combination for these trucks these years, and it lists year by year and model by model etc.
if you need info like this then PM or email me
  #21 (permalink)
Old 11-18-2010, 05:46 PM
prostreet6t9's Avatar
Differential/Driveline
1972 C20 Truck Chassis w/ Leaf Springs
603322-1 Standard 4.10
603322-2 Powr-Lok 4.10
603322-3 Standard 4.56
603322-4 Powr-Lok 4.56
603322-5 Standard 3.54
603322-6 Powr-Lok 3.54
  #22 (permalink)
Old 11-18-2010, 05:47 PM
1972 C20 Truck Chassis w/ Coil Springs
603321-1 Standard 3.54
603321-2 Powr-Lok 3.54
603321-5 Standard 4.10
603321-6 Powr-Lok 4.10
603321-7 Standard 4.56
603321-8 Powr-Lok 4.56
  #23 (permalink)
Old 11-21-2010, 01:38 PM
Mertz's Avatar
Here is what I found on the diff These numbers were upside down and read C-30255 The only G codes in the glove box are G70 and G50 for leaf springs. I did find a tag that read 41.10. Before I checked the numbers I put the rear end in the air and spun the tires to try to count drive shaft revs. If I spin the left tire forward the right tires spins backwards and visa versa. The problem is that the drive shaft does not continually spin like it is only catching part of the time. There are 10 bolts on the cover and appears to be a Dana 60 although I found other sites that say it could or should be a GM 8.875. (A little more web surfing and I am pretty sure it is a Dana 60. It has the 60 at the bottom. I could read the 0 but was not sure about the 6) I am going back under to see if I can find numbers on the tube.
The engine does not rev very high at highway speeds. I have had it to 85 with no problems and it could have gone more. It is weak at 35 mph.
Is this a limited slip differential? Could there be something wrong with it that is allowing it to slip when it shouldn't. I have never been able to burn the tires.
Where would I find the numbers you list? The ones I found are on the passenger side of the diff housing on top and are upside down.
This truck is pretty much stock except what I did to it. It shows 152,000 miles and I believe that is original. I don't think there has ever been a rear end swap or gear change. If it had I would guess the tag would be missing.
  #24 (permalink)
Old 11-25-2010, 12:25 PM
Mertz's Avatar
As a little turkey day fun I went out and played with my truck. I should mention it is snowing and about 13 degrees. I jacked up the rear and did the tire rotation check and got a little over 4 turns on the drive shaft with 2 turns on the wheel. That would mean the tag is correct and I have 4.10 gears. Now what? My transmission guy said there is probably nothing wrong with the torque converter. I did read somewhere that if the stator is allowed to spin backwards it will have no low end but scream on the high end which is just what mine is doing. I did one other thing and that was to put a clamp on the PCV hose on the carb. It was somewhat loose. It seemed to run a little stronger. It also seemed to run a little stronger when I pinched the hose. No change on the vacuum gauge which is at 16 at idle which is about 2 low from what I have in the summer. I think it is running pretty good because I don't have a choke connected and it started after a little cranking to get gas to the carb.
BTW I also checked for voltage at the coil and got battery voltage (12.43v) with ignition off and alternator voltage with it running (14.21v)
  #25 (permalink)
Old 11-25-2010, 02:58 PM
akhappyjack's Avatar
Big rear Big tires
lack of power @35 does it struggle to get to 85? or just flatten's out at 35 and starts to pull above 40-45
  #26 (permalink)
Old 11-25-2010, 06:37 PM
Mertz's Avatar
Once it gets above 35 or 45 it takes off like a rocket. I have no trouble getting from 50 to 85 and it does not over rev. it is very sluggish from zero to 45.
  #27 (permalink)
Old 12-11-2010, 10:22 AM
bosco200's Avatar
My 72 C20 has 4.57's and it starts screaming at 50mph and starts suckin down gas like crazy...but im gunna throw a 350 motor and T56 tranny in there...has a 250 straight 6 with a 4 speed manual now.
  #28 (permalink)
Old 12-11-2010, 11:05 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i would try the tire front to rear swap, just to see what it does.
its fast, easy and free
  #29 (permalink)
Old 12-11-2010, 09:44 PM
Mertz's Avatar
After some more research I find that the stock tires and the ones I have on now are the same diameter so I am using the 4.10 rear end as designed. The change from front to back will help. Right now the truck is in the shop with about 4' of snow in front of the door so it won't be going anywhere soon. I still think that with the 4.10s I could have a weak engine and still burn rubber.
Mazda Pickup Truck 1990, model B2200 rear end awbazar Transmission - Rearend 4 12-17-2009 05:15 AM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Rear End vibration driving me insane 973kgt Transmission - Rearend 41 11-13-2008 11:01 PM
will a '69 Chevelle rear end fit into a '70 Chevelle? SMO'KUM UP Introduce Yourself 2 09-17-2007 07:15 AM
Rear end no oil, big mistake. anyoldchevy Transmission - Rearend 14 06-23-2007 09:28 PM
