Rear end blues - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2006, 06:56 PM
Rear end blues
I have a 55 Chevy. Rear end is all stock except for ring and pinion gear, which is a 4.11 gear and posi. I want to change to a 3.55 gear put have been told this gear set will not bolt into my third member. I have found another third member with the gear I want but it is an open one not a posi. No one around here can tell me if I can take my posi internals and fit them in this unit to make it a posi. I am still checking other places to see if I can find one already set up or possibly swap mine. Motor is a 327, trans is TH350. Any input on this problem would be well appreciated. THANK YOU 55alive.
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 09:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
