It would be easier .. and more cost effective IMHO to just find another rear end ... most Ford 9 inch rears come with the 5 on 4.5 wheel pattern. Find one as complete as you can ... I find that a 57 to 59 Ford car rear is the most perfect fit most Hot Rod projects.
Here is a list of common Ford rear end widths ... http://www.mustangsandmore.com/ubb/F...imensions.html The measurements are taken this way ... ![]() Here is a good tutorial on 9 inch Fords ... http://www.kevinstang.com/Ninecase.htm |
Is the rear housing the width you need for the project? If so, just have the axle flanges redrilled for the 4 1/2" pattern.
What type of brakes are you planning to use? |
ok let me see if I can answer everyone questions...
First the rear end IS the correct length... so that is good. I guess I failed to state that my major concern was that someone told me I couldn't mount up the brakes (calipers, disc, etc). I plan on using disc brakes all the way around, and they said you couldn't do that without going to a WHOLE lot of trouble (if it was possible at all) As far as finding another 9" ford rear end,.. gosh,.. I was 3+ months of REAL HARD searching finding this one. Not many left where I am. Several race tracks, and most of them used up in race cars. I was lucky to find this one. Thansk fort the help so far,... Hope I can get some reliable info... |
STAINLESS STEEL or MASTER POWER BRAKES should be able to outfit you. |
[QUOTE=KULTULZ]Being as it is not a dedicated FORD build, finding a disc brake conversion (kit) for the rear should be fairly easy. Most use GM components and you just have to measure your axle flange size.
QUOTE] OK,.. thanks... Just so I'm not confused... You can mix and match Ford and GM parts here..??? A GM bracket to hold the Disc brakes, calipers, etc will fit on the Ford rear end housing.?? Then everything will work with my Ford axels?? Proper clearance, spacing, etc?? Just wanted to make sure before I got all excited. LOL |
9 inch 5 on 5 ford???
As I recall the 5 on 5 were used on Lincolns and were usually 9 3/8 ring gears . Usually too wide for street rods. Some of the stuff will interchange. It's usually better to find the right size and bolt pattern to start with and will cost less in the long rum.....retired ford engineer
| Bent Pinion In Rear End...? | 2 Fn LoW | Transmission - Rearend | 5 | 11-05-2005 07:10 PM |
| 38 Dodge rear end | dwayne_tn | Transmission - Rearend | 5 | 09-09-2005 09:35 PM |
| Rear end identification help | 71gtx | Transmission - Rearend | 1 | 11-07-2003 07:14 PM |
| Rear End Change... | Juicer | Transmission - Rearend | 0 | 10-07-2003 10:23 PM |
| Rear end swap for '53 Chevy truck | Bruce H | Transmission - Rearend | 4 | 12-01-2002 11:43 AM |
