The taller tires will have some effect on the final drive ratio but they're not going to change the gear ratio of your rear end.
To determine what gears you have, get the entire rear end off the ground and rotate the passengers side tire one complete turn. Count how many times the drive shaft rotates for one turn of the rear tire. For example if the drive shaft rotates 3 and a half times then your ratio is 3.50 if it rotates just a shade over 4 times then its probably a 4.11 etc. Besides actually having the factory tag on the rear indicating the ratio or opening it up and actually counting the teeth, this is the easiest way to figure your gear ratio. Centerline |
The richmond gear calculater shows
3000rpm 70mph 26 in tire It says 3.32 You have 3.31 gears http://richmondgear.com/101032.html
Ontario Rodders |
For a 235/50/18 tire at 70 MPH I get:
2858 RPM's with 3.31 gears 2953 RPM's with 3.42 gears 3065 RPM's with 3.55 gears 3220 RPM's with 3.73 gears http://www.geocities.com/z_design_st...ion_z28_6.html |
