Rear end change for 53 Chev
OK we have gone through many questions on changing a Chev to open drive line, but from these I find no definitive answer on an easy swap. So here are the stats on a 53 drive line.
2" springs 54" backing plate to backing plate 45.5" center to center on the springs Is there a matching rear end that will slip into this configuration? I have been told 1st Gen Camaro and also 2nd gen Camaro, but the only Camaro rear end I have located is 2.5" on the springs. Another rear end would be a 55-57 unit and I am definitely going to look at this opportunity. I can't weld and it is hard to move a car to a welder with the rearend removed so I am looking for answers, if any are out there. thanks |
53 rear-end swap
Is this a car or is it a pick-up?
I just got through swapping everything from a 1979 Chev. 1/2 ton into a 1949 Chev 1/2 ton. The IFS from the 79 was 1 and 1/2 inches wider than the narrowed 49 front frame. This was shimmed with 3/4 steel plate. The rearend fit perfect, using the 49 springs and longer u-bolts. Had to Manufacture a drive-shaft to tie everything together. The only problems I have encountered thus far is hooking all the computer controlled suystems up. |
This is a 210 Sedan so unfortunately the changes you made wouldn't help. Since I posted this thread I have learned that any change I make will require spring changes so with this info I will pickup a Camaro rearend and proceed.
Thanks for your response. |
| 8.8 Ford rear end in my 79 G body Malibu | 79 Malibu327 | Transmission - Rearend | 4 | 05-20-2007 02:26 PM |
| ford rear end indentifer | 40blackie | Transmission - Rearend | 15 | 01-23-2006 07:39 PM |
| 82-92 camaro posi rear end info | NoEgoMan100 | Transmission - Rearend | 4 | 10-21-2005 02:22 PM |
| Rear end identification help | 71gtx | Transmission - Rearend | 1 | 11-07-2003 07:14 PM |
| Rear end swap problems | datsun dale | Transmission - Rearend | 1 | 12-17-2002 10:50 PM |
