rear end codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2013, 04:26 PM
rear end codes
I have been trying to understand these rear axle codes. I get the pages that state what there are but not what they mean. the chart states this. my codes are
Rear Axle Ratio:
The AXLE code is a number or letter indicating the rear axle ratio and standard or locking type axles.
Conventional lock ratio
6 O 3
What is conventional 6 mean?
What does lock O mean?
I get ratio 3?
any ideas?
Rear Axle Codes
Conventional
Lock
Ratio
2
K
2.75
4
M
3.4
6
O
3
9
R
3.25
7
P
3.55
Old 01-05-2013, 04:31 PM
rear axle code
Not sure what happen with all the threads.
Question is what is a conventional 6 rear axle?
and what is a lock "O" rear axle?
Old 01-05-2013, 05:36 PM
big gear head's Avatar
High Performance Rear Ends
Don't understand the question.
Old 01-05-2013, 06:47 PM
On the car door the axle code is 6.
When I go to a site to explain codes 1975 Data Plate Decoder
there are 3 catagories
Conventional
Lock
Ratio
Convention choices are 2, 4, 6, 9, 7
LOck choices are K, M, O ,R, P
Ratio are 2.75, 3.4, 3, 3.25, 3.55
Respectivley
My code is conventional 6 which matches with lock O and ratio 3.
What does conventional 6 mean and what does lock O mean?
I attched the website I used but all of them are the same that I viewed.
Old 01-05-2013, 07:09 PM
What car is this?
Old 01-05-2013, 07:20 PM
it is a 1975 Ford Gran Torino Sport
Old 01-05-2013, 08:24 PM
Look at the tag on the rear end. It will tell you what you have. Ford tags have 2 lines of codes. The bottom line will give you the gear ratio, differential and ring gear size. It will read like this. 3L.25 9 xxx. This is a 3.25 gear with the Traction Lock differential and a 9 inch gear. If there is no L in the gear ratio then it has a standard differential.
My guess is that you have a standard differential with 3.00 gears.
The Following User Says Thank You to big gear head For This Useful Post:
zjosh27 (01-06-2013)
Old 01-06-2013, 12:39 AM
SSedan64's Avatar
I think "BGH" is correct. Open Diff w/3.00 gear.
Ford Diff codes, Tag Info >> Ford Rear Axle Assembly Identification - Page 01 - FORDification.com
The Following User Says Thank You to SSedan64 For This Useful Post:
Old 01-06-2013, 03:43 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Conventional = open type differential
Lock = limited slip diff
(you cannot have both, so in your case, "6" = conventional or open diff, aka 'peg leg' because usually only one rear tire spins at a time)
Ratio "3" = 3.00:1 final drive ratio
IIRC you should have a 9" but if you're not sure, you can check the ID info here.
Often the rear gear in the fvehicle no longer matches the data plate. Use Gear ratio check if you want to verify what ratio you have.
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 01-06-2013, 04:15 PM
Thank you guys for replying. You were very helpful.
I was interested in understanding what the code were more than the accual rear end.
But I did what the 9inch.
So I have a conventional 6 ( still not sure what the six is for)
What is the difference between a conventional 2, 4, 6, 9 or 7
But it make since the Axle would be and Open Diff with 3.0 rear.
Any thought s on what the K, M, R or P refers to for the lock
Old 01-06-2013, 04:43 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
You just have to understand how to read the chart ... (see attachment)
2 and K are both in the first row of that chart, and both are 2.75:1 Ratio.
"2" is conventional (non-locking) and "K" is locking.
The "6" indicated on your certification label puts you in the 3rd row of the chart ... and "6" tells you that it's a conventional diff.
Reading across to the 3rd column ... the ratio is 3 (3.00:1)
Makes sense now?
The Following User Says Thank You to 66GMC For This Useful Post:
Old 01-06-2013, 04:53 PM
Yes it does. Thank you! I am not a mechanic but I do like to understand what people are talking about.
Did you see my other thread about the right axle for my project?
Old 01-06-2013, 05:31 PM
66GMC's Avatar
I found it and replied to it as well.
Old 01-06-2013, 10:20 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
These numbers and letters can be looked at as arbitrarily assigned, or they might denote something in particular to the factory.
My thoughts are, these different numbers/letters (that mean the same thing like 2, 4, 6, etc. and K, M, R, etc.) are used for reasons that only the factory knows for sure.
But for our use, they mean what the chart explains, and beyond that you'll have to use other clues like bearing diameters, axle spline counts, and et cetera to define an axle further.
BTW, nice ride. You can turn that Torino into a fire-breather if you want, plus even looks/drives good stock.
10 bolt GM rear end codes? 303oldskool Transmission - Rearend 11 10-04-2012 05:57 AM
Trans & Rear end RPO Codes jamesnorris Transmission - Rearend 4 04-24-2009 08:00 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
s10 rear end rpo codes S10lady36 Transmission - Rearend 2 10-14-2003 08:20 AM
