Rear End Conversion?
Hey Guys,
I was wondering if there was a cross reference site that I could use to see which pozzi rear end would fit my 72 chevelle. Or does anyone know off hand? Its a 72 Malibu with a 383 stroker. 12 bolt one wheeler peeler. Any info would be helpful. Thanks Guys. Mike |
Thanks for the info.
Ill chedk around locally for a rear end with the specs you stated. Another question: Im not much of a differential guy... Can I just swap out the internals of the existing rear end and make my current one a posi? or do I need to get an entire new one? Thanks, Mike |
change to posi - NastyZ28.com
Read this, post number 2. This is for the 8.5 10 bolt. The only difference is that the 12 bolt has 3/8 ring gear bolts with right hand threads and the torque on those bolts is 40-45 foot pounds. All you need is a new Eaton Posi, a set of bearings and a super shim set. You need to know what your gear ratio is before you buy anything. |
Thanks again. I am going to figure out what my gear ratio is and then order the correct pozzi I need.
Thanks for the help. Mike |
Most people seem to want to go to Summit or Jeg's for rear end parts. I recommend Tom's Differentials, Randy's Ring & Pinion or DTS for these parts. They are not just some people sitting in front of a computer reading what is on the screen. They know rear ends and will get you exactly what you need at a good price. They also have better parts that Summit and Jeg's.
| Rear End Conversion | bigrix66 | Suspension - Brakes - Steering | 11 | 04-29-2008 07:28 AM |
| 84 Z28 Rear End TO Posi Traction Conversion | x711 | Transmission - Rearend | 2 | 08-07-2006 07:51 PM |
| 91 Mustang Disc Conversion and rear end help | sha_ba_do_bang | Transmission - Rearend | 1 | 05-29-2006 06:51 AM |
| 9" conversion for 48 ford rear end | big mal | Transmission - Rearend | 1 | 08-23-2005 09:47 PM |
