Rear end gear ratio in 1977 chevy pick up. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2011, 03:12 PM
Hello, I want to know what gear ratio i have in the rear end of my 1977 pick up. The left side of axle tube has Gm 64 Stampd on it. The right side rear end housing has 3896839 stamped on it. The top right side of axle tube has KDA W0232 stamped on it. I hope this will help to identify the rear end.
Old 09-19-2011, 07:04 PM
S10 Racer's Avatar
http://www.warsprints.com
The only accurate way is to remove the cover and count teeth. Those numbers really don't tell the average guy anything.
Old 09-20-2011, 06:53 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you have an RPO sticker inside the glove box, you might find the code there. A list of what the codes mean is HERE.
HERE is an article on checking rear gear ratios.
Old 09-20-2011, 09:45 PM
thank you
Hello S10 Racer , I want to say thanks for your response.
1956 Chevy sedan rear end gear ratio? goodold56 Transmission - Rearend 3 02-28-2011 07:11 PM
1977 F-100 Rear Gear questions Chevy 84 Transmission - Rearend 6 06-20-2010 09:01 PM
GM 7.5 in 1977 Oldmobile. Rear gear change cars4megames4u Transmission - Rearend 10 11-17-2008 09:16 PM
74 chevy C-10, RPMs seem high. rear end gear ratio? BowTie74 Transmission - Rearend 7 11-17-2008 07:03 PM
1978 chevy truck rear end gear ratio? gpeak Transmission - Rearend 2 11-25-2003 11:54 PM
