rear end gear ratio
Trying to figure out rear end gear ratio without takeing rear end cover off. Went on youtube and got some instructions. Couldn't remember how to do it. The video I watched showed to jack the car up and roll the rear wheel over ten times and count the number of times the driveshaft turns. In this paritcular video the drive shaft turned 48 times when the tire was rotated ten times thus being a 4.89.
I jacked my car up marked the driveshaft and the right rear wheel( both wheels of the ground) rotated the wheel ten times and the drive shaft turned 12.2 times. This comes out to a 1.21. I talked to friend of mine and he said one wheel needed to be on the ground. I let the car down and jacked up the left side. Rolled the wheel ten times and came out with the same thing. I let the car down and jacked up the right side. Rolled the wheel 10 times and came out with the same thing. I don't understand what is going on. If I roll the wheel over once the driveshaft turns over approximately one time. Can someone tell me what is going on? |
ration
I think it is out of a79 or so camaro but I am not sure. Where would it be stamped or tagged on the rear end.
Like I said when I roll the wheel one complete revolution the drive shaft like 1 1/8 turn like it is almost a one to one. Any more suggestions? Thanks |
It will be stamped on a machined smooth spot. This is usually where the rear end cover is bolted, it will have a wide point that the cover isn't covering and the number is right there. Often it's on a machined area between the axle tube and the rear cover. If it's a drop in pumpkin like a 9" they are on the front on a machined area on the cast third member.
But on that Camaro I seem to remember a triangular tag. Brian |
Here is some info that may help. I know your's is later than this but it's the idea of where to look. After seeing these links I did remember that the it could be stamped on the tube and not a machined area. I had a 67 12 bolt rear in my truck for years and that IS where it was....ahhh the mind is going.
http://chevellestuff.net/qd/generic_rear_axle_info.htm http://stevescamaroparts.blogspot.co...camaro_11.htmlBrian Last edited by MARTINSR; 01-01-2013 at 11:43 AM. |
If you are only turning one wheel then you need to turn it twice as many times as you would if you turned both wheels together. So if you came out with 1.21 you would actually have a 2.41 gear, which was comon in the days before overdrive transmissions. Be very careful what you watch on youtube. There is a lot of completely wrong stuff on there, especially when it comes to rear ends. The Camaro rear ends have the code stamped into the right axle tube on the front side.
rear end ratio
Thanks to all the response. I' will look for the numbers on the rear end tomorrow and see if I see anything. The last post by big gear head makes sense. I bet it is a 2.42 Thanks to all.
rear end ratio
Went and did this. I have a 700r4 transmission. 28" tall rear tires. These are the rpm and seeds I got with my gps
1st at 2,000 = 20mph 1st at 3,000 =31mph 2nd at 1,000 = 20mph 2nd at 2,000 = 34mph 2nd at 3,000 = 51mph 3rd at 1,000 = 31mph 3rd at 2,000 = 60 mph 3rd at 2,500 = 70 mph od at od lockup 1,500 = 70 mph Any ideas on rear end ratio. |
2.73 rear axle ratio with 3,000 rpm on the tach,28 inch tall tires=30 in first/57 in second/92 in third
at 2,000 rpm= 20 in first// 38 in second// 61 in third using 3.06 first gear ratio///1.62 second gear ration///third 1:1 |
rear end ratio
Thanks to all. I believe it is a 2.73. Thanks Vinnie
A little late... Check gear ratio
| Change gear ratio on rear end? | mars77 | Transmission - Rearend | 2 | 09-14-2009 12:27 PM |
| Way to check the rear end gear ratio........... | Trans Am Tony | Suspension - Brakes - Steering | 4 | 06-19-2007 08:25 AM |
| rear end gear ratio | mechanix54 | Introduce Yourself | 2 | 02-21-2006 11:22 PM |
| VIN # and rear end gear ratio | olds79 | Transmission - Rearend | 1 | 11-24-2005 08:17 PM |
| What is the gear ratio for a GM rear end? | jpd37 | Transmission - Rearend | 6 | 02-23-2004 12:52 PM |
