rear end gear recommendations for 327? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2011, 02:11 PM
I have a 68 chevelle with a .40 over 327 sbc
291 heads 2.02s
60102 voodoo cam
shorty headers
g team single plane intake
670 holley vac sec
hei distributor
th350 trans automatic
running stock 8.5gm 10 bolt rear end no posi not sure on gear, should be 2.30s or something highways gears nothing beefy, what would you fellas recommend for my current set up? I was thinking 3.55s or something in that ball park, does this sound about right?
Old 09-27-2011, 05:47 PM
Ford Junkie's Avatar
No substitute for cubic inches
These guys are good but a couple things more are needed info wise. Planned usage i.e. street cruising, strip racing or combo of both, as well as rear tire size and current stall on your converter. Here is a link to a calculator that will give you a pretty close idea of what each ratio will give you for RPM's at what ever speed you put in.
http://www.ringpinion.com/Calc_RPM.aspx
HTH,
Tony
Old 09-27-2011, 06:19 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Yes 3.42s or something in that range would work well but as stated above more info would be nice, cause all this really depends on what your driving plans are going to be. JMO
Is this going to be a cruiser or drag car or both ?
Cole
Old 09-28-2011, 04:32 PM
gears
thanks fellas, and here is more info. to be more specific
converter is rated 1800-2000 with th350
tire height on rear is 275 70 R15, so would that be 30.16 tire height?
245 60 R15 on the front
This 68 chevelle is going to be a a driver not a drag racer, but I would like to have a little more grunt off idle, but also not kill my mileage either, something in between since I don't have an over drive trans. This is my first real build and did not take into account I should have started at the rear of the car first.
Ford Junkie I went to the site but was not sure how to figure out R&P ratio and AOD? This is all new to me, I think I got the tire height 30.16?
Old 09-28-2011, 05:06 PM
>>>>This 68 chevelle is going to be a a driver not a drag racer, but I would like to have a little more grunt off idle, but also not kill my mileage either, something in between since I don't have an over drive trans. This is my first real build and did not take into account I should have started at the rear of the car first.<<<<
This happens alot, no big deal just a pain when you realize the cam you selected is a dog with the current gear you have. From the spec's I see on that cam it should be pretty nasty in a 327 as it will act like a bigger cam in less cubic inches. 1400 to 5700 is based on a 350 build. It probably will wake up around 2000 and start pulling from there in the 327. This is just guessing on part so take it for what it's worth.
>>>>Ford Junkie I went to the site but was not sure how to figure out R&P ratio and AOD? This is all new to me, I think I got the tire height 30.16?<<<<
You got the tire size correct. Now go to the top row of boxes and enter 3.42 in the ratio box, enter 30.1 in the tire size box then enter your speed in the last box, then click solve.
2548 rpm's @ 65 and 2156 rpm's @ 55
Changed gear ratio too a 3.73 and got 2779 rpm's @ 65 and 2351 @ 55
mileage is probably headed for the toilet.
Old 09-28-2011, 10:13 PM
I understand now, I feel kind of stupid! Ratio was my new gearing I was looking for, got it. Well I am going to be doing a lot of highway driving so maybe I will stick with what I got for now, until I blow that stock rear end
And yes it does pick up around 2000 rpms like a raped ape. Plus some loss I am sure on the bottom end with that single plane intake. But sure puts a silly grin on my face when the secondaries open and the top end pins you back in the seat
Old 09-28-2011, 10:26 PM
Glad you got it figured out! Took me a couple of tries too to make my head understand how to get the answer I was hunting. I'm not real computer smart.
I would say Cole hit it pretty close with the 3.42. That would put you right on the bottom of your power range @ 55 mph. Just remember your moving a lot of car with a small engine so it has to be set up in it's power range for a good performance feel.
Be safe and don't feed the bears out there,
Tony
Editted called cole cobalt
Transmission and rear end recommendations for a 91 mustang 5.0 jkeckss Transmission - Rearend 8 08-22-2011 09:24 AM
Ford 9" rear end gear oil recommendations vettesplus Transmission - Rearend 4 05-29-2010 10:41 AM
New Posi and Gear Installation...Shop Recommendations in Calgary wickster Transmission - Rearend 0 04-24-2006 12:33 PM
Recommendations: Rear End Speciality shop, Phoenix area? MM in NM Transmission - Rearend 0 11-13-2005 11:45 PM
Rear gear choice, Gear to Tow icegnome Transmission - Rearend 3 12-03-2002 08:17 AM
