-   -   Rear end gear selection on 69 C10 for drag racing (http://www.hotrodders.com/forum/rear-end-gear-selection-69-c10-drag-racing-227591.html)
1952 CHEVY 12-26-2012 11:26 AM
Have a 1969 c10 that i plan on using on the drag strip ( 1/8 mi.) occationaly . Has 35/350 combo,12bolt rear. Motor is stock bore & stroke,600 holley, dual plan intake,670h comp cam,2200 stall converter. What rear gears should i use with 29 inch hoosier slicks?
gearheadslife 12-27-2012 03:55 PM
you drive this on the street?
those gears above are mighty tall. and iirc not aval for our truck 12 bolt
1952 CHEVY 12-28-2012 04:21 AM
Yes i do drive it on the street (about 120 mi. A year) and thanks much.
632Mantis 12-28-2012 06:33 PM
I'm gonna say start with 4.56 and see if that would be a happy medium for ya.
If you go lower, you won't like the street RPM's.
If you go taller, you will just run slower track times.
It's a trade-off.
vinniekq2 12-30-2012 01:46 PM
doesnt sound like a drag race engine?why not use a compromise ratio or race it as it is?
1952 CHEVY 01-02-2013 04:51 AM
This is not a race engine. And have 3.73 gears now. Just want to have fun,but be some what competive.
632Mantis 01-02-2013 09:50 PM
29 rears ain't that tall.
Not a race engine? So you shift at what... 6500 rpms?
Maybe you should try 4.11-4.30:1
4.56 might be too low.
I have 33's on the back of my truck, and my motor is 6500 rpm max.
I had 4.56 in my Ford 9" to start with, and it was TOO LOW.
I got 4.11's in it now, and they are perfect for what I do. ( street / strip )
Of course, I have a hella-torquey bigblock up front, so I can pull a taller gear with ease.
1952 CHEVY 01-03-2013 04:56 AM
Thank you much. I will give it a go when the snow is gone.
