Rear end gear selection on 69 C10 for drag racing - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2012, 12:26 PM
Have a 1969 c10 that i plan on using on the drag strip ( 1/8 mi.) occationaly . Has 35/350 combo,12bolt rear. Motor is stock bore & stroke,600 holley, dual plan intake,670h comp cam,2200 stall converter. What rear gears should i use with 29 inch hoosier slicks?
Old 12-27-2012, 04:55 PM
Banned
you drive this on the street?
those gears above are mighty tall. and iirc not aval for our truck 12 bolt
Old 12-28-2012, 05:21 AM
Yes i do drive it on the street (about 120 mi. A year) and thanks much.
Old 12-28-2012, 07:33 PM
Bye Jerks
I'm gonna say start with 4.56 and see if that would be a happy medium for ya.
If you go lower, you won't like the street RPM's.
If you go taller, you will just run slower track times.
It's a trade-off.
Old 12-30-2012, 02:46 PM
vinniekq2's Avatar
doesnt sound like a drag race engine?why not use a compromise ratio or race it as it is?
Old 01-02-2013, 05:51 AM
This is not a race engine. And have 3.73 gears now. Just want to have fun,but be some what competive.
Old 01-02-2013, 10:50 PM
Bye Jerks
29 rears ain't that tall.
Not a race engine? So you shift at what... 6500 rpms?
Maybe you should try 4.11-4.30:1
4.56 might be too low.
I have 33's on the back of my truck, and my motor is 6500 rpm max.
I had 4.56 in my Ford 9" to start with, and it was TOO LOW.
I got 4.11's in it now, and they are perfect for what I do. ( street / strip )
Of course, I have a hella-torquey bigblock up front, so I can pull a taller gear with ease.
Old 01-03-2013, 05:56 AM
Thank you much. I will give it a go when the snow is gone.
rear end for 75 c10 zoomo Transmission - Rearend 2 10-13-2010 08:37 PM
Rear gear selection help karfever Transmission - Rearend 1 07-28-2010 08:22 PM
9" rear end "drag race gear" what does that mean? 84Z Transmission - Rearend 2 01-29-2006 05:08 PM
narrowed rear end and gear selection Blob Transmission - Rearend 7 11-26-2003 08:40 PM
front end alignment specs drag racing snakejake Suspension - Brakes - Steering 3 04-27-2002 12:05 AM
