Which rear end gear wight?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2009, 12:23 AM
labreejr's Avatar
Which rear end gear weight??
Im goin to change my rear end cover soon because its leakin and not attractive!! Which weight do I use, synthetic or conventional? It's a 84 Cutlass with the factory 3:73 8.5" rear. Up front is a 383 stroker, 450hp, 350 trans but gonna switch to a 200-r4. Also I was lookin at these Trans-dapt clear rear end covers(made of bullet proof glass), anybody ever use these?
Old 01-06-2009, 01:35 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Those clear covers are pretty lame... IMO
Use a good gear lube according to your type of diff, stock cover, no silicone just a dry gasket. 85w90?
Don't paint it lime green or bright orange.
"Dollars are like votes, except that they actually count."
Old 01-06-2009, 07:44 AM
SSedan64's Avatar
I'm with C-10, the clear covers are more for Off-Road use. To see when water gets in past seals. If you plan on an aftermarket cover get one of the aluminum TA or LPW covers with the girdle for extra cap strength.
Old 01-06-2009, 01:45 PM
prostreet6t9's Avatar
Differential/Driveline
Just use a 80/90 GL5 rated or better,with posi additive if needed. I've seen no benefits of using synthetic in your application,plus the synthetic cost's more.
What rear end gear ratio to choose? Rodney Mackey Transmission - Rearend 18 04-24-2007 06:24 PM
Is my rear end gear pattern ok? Warrant Transmission - Rearend 1 04-22-2007 10:34 PM
rear end gear ratio mechanix54 Introduce Yourself 2 02-22-2006 12:22 AM
Rear End Gear Ratios JRS1967 Transmission - Rearend 3 01-07-2004 01:09 AM
80/90 gear lube ok for sm-465 and non possi rear end? zachscc Transmission - Rearend 2 03-02-2003 06:06 AM
