Rear end Gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2008, 06:39 PM
race10's Avatar
Rear end Gears
I was wondering what would be a good gear ratio to run in my 1992 S-10. My truck is going to be a 383 stroker pushing anywhere 400 to 450 HP just depending on what i do to it. This truck is usually going to be a fast street truck and I can run down my local strip now and then. If anyone has any ideas that would be great.
Thanks, Spencer
Old 02-27-2008, 06:46 PM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
Depends on what you are planning for tires and tranny as well -- but generally speaking, since you have plenty of power and pep, sticking with a normal street type ratio (3.00 - 3.30) will give you drivability and better economy than something more strip oriented.
Old 02-27-2008, 06:54 PM
life is a temporary assignment
3:73 Gear is good for the street and track.
Change 4.11 to 3.08 rear end gears cares Transmission - Rearend 4 08-13-2006 02:46 PM
spinning the rear end gears.. onecoomofo Transmission - Rearend 4 06-21-2004 07:19 PM
anybody take a guess what my rear end gears might be? smlblcks10 Transmission - Rearend 7 04-22-2004 12:46 PM
65 Chevy Rear End Gears mweber Engine 3 01-03-2004 05:05 PM
Changing rear end gears... chevyelc81 Transmission - Rearend 1 07-23-2002 08:52 PM
