The gear ratios are the ratio of teeth on the Ring gear to teeth on the pinion, example 37 ring gear teeth and 10 pinion 37/10 =3.7
If your shooting for what is most common. A lot will give you their own opinion on what is street/strip ext. choosing the right gear for you can be broke down into a science based on engine/transmission/weight/tire size and so on. Your driving habits also play a great deal into this. Like are you more in tune to run the street. Or the strip. Or both. The most common aftermarket gearing you will find in street driven heavy iron is 323 / 355 / 373 and 410/411 after that you are heading for mainly strip. Most gear manufactures web sites will give very detailed info on choosing the right gear. Not to mention the tech lines. Richmond I have always found to be outstanding with customer service. Hope this helps. I am sure you will get many opinions on this question. It is one that can start a great debate. Lol . may your axles turn freely ……twist
| Ford 9" rear end vs stock 89 chevy truck rear end | jimmy p | Transmission - Rearend | 2 | 12-07-2005 03:28 AM |
| spinning the rear end gears.. | onecoomofo | Transmission - Rearend | 4 | 06-21-2004 06:19 PM |
| anybody take a guess what my rear end gears might be? | smlblcks10 | Transmission - Rearend | 7 | 04-22-2004 11:46 AM |
| 65 Chevy Rear End Gears | mweber | Engine | 3 | 01-03-2004 04:05 PM |
| Changing rear end gears... | chevyelc81 | Transmission - Rearend | 1 | 07-23-2002 07:52 PM |
