Rear End Gunk?
Good day, Good day.
Dre' with the '80 Mali is here again, with a question for you all. First off, a general question. How much difference does a clean rear end with fresh fluid make if your rear end is old and dirty and hasn't been changed in about a decade? I just changed my rear end "dope", and when I took the cover off, it was thick, gooey and quite foamy to my surprise. A little info on the car- I found the body in a junkyard and put in a souped-up 350 sbc and a th400 trans with a shift kit and a 3000 stall convertor. I'm sure this is the stock rear end (I don't have Posi) and the stock gears (any clue to the ratio?) and it looks like it hasn't been changed since the car was made back in the day *l* But where did the foam come from? I wanted to take a pic and post it for you guys. And will a 12 bolt rear end (I have a ten bolt) Help out my performance?
