Rear End Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2005, 11:39 PM
TWOPLYM's Avatar
New Member
Rear End Help
Hey Has Anybody Out Here Built A Plymouth Rod Im In The Process I Have Swapped Rearends But Need To Know If The Stock Leaf Springs Will Work The Spring Perch Are Small Like 1 3/4 Believe I Found Some That I Need To Weld On To The Rearend How Should I Position It
Old 07-08-2005, 04:59 PM
Wiki Edits: 49
Just do a search on pinion angle or setting pinion angle. You'll find plenty of information on how to set up your rear end.
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 09:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
