rear end help????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2006, 07:09 PM
rear end help?????
Hi,
I want to put a 3:73 posi into my 1981 chevy short box. I've been looking all over and have confused myself with all these different numbers. Like 7.5'' rear ends,, and 7 5/8'' ,, and 8.5'' rear ends. Also with 28 spline and 30 spline. Now it figures when I had mine apart last, i did not count or measure anything inside it, besides the gear ratio.
The truck is a 1981 chevrolet silverado. 1/2 ton
The rear end is a 10BOLT 2:73 gear ratio
The numbers i found on the diff housing are ( all this was found on the housing, facing the motor, on the driver side, and the passenger size. I did not find anything on the axles tubes, but i am going to look again tomorrow with a wire brush instead of the sand paper i had at the time.
GM 36 1254333 and L20
I have no idea what these numbers mean, or how to figure out what this axle is from, or if its the original axle.
The brakes are 2 1/2 '' wide brakes, which i believe are the larger of the two sizes. And the u-joints are the larger of two sizes. If this helps at all.
If anyone can please help me find out what type of posi 3:73 I need to buy taht will fit into this rear end, that would be just amazing.
Thanks in advance ,
Adam D
Old 05-10-2006, 09:57 PM
1/2 ton should be a 8.5" 10 bolt...
Count the axle splines
Make a list of what you want (gear, posi, beaing/shim kit. axle bearings & seals), etc
Call 800-521-0628
DTS in Detroit....
Ask for sales
Old 05-10-2006, 11:22 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
And your axleshafts and spider side gears have 28 splines.
Old 05-11-2006, 04:57 AM
So your 100% sure my axles are 28 spline? Because I am thinking about buying what i need on ebay, but I don't want to buy something that won't work.
Adam D
Old 05-12-2006, 04:50 AM
73oldsman's Avatar
Originally Posted by AdamGD
So your 100% sure my axles are 28 spline? Because I am thinking about buying what i need on ebay, but I don't want to buy something that won't work.Adam D
Man, the only way too know for sure is to tear into it and count them yourself. That's the only way to keep from getting something you may not need.
Old 05-12-2006, 04:57 AM
thanks for all your help.
Adam D
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 07:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 06:32 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 10:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 07:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 07:38 PM
