rear end help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2002, 04:05 PM
Post rear end help
Hi i am building a drag car it is an 84 camaro i need to know how wide (the length) of the camaro rear end and i am looking for a full list of what length 9" rear ends came in what.
Thanks!!
Tom
Old 11-16-2002, 04:58 PM
Post
I put one out of a old Bronco for a kid years back. Unsure of the year it was but it was the old stlye small one. I'm 90% sure that is what he said it came out of. the length worked well as it was abit smaller. We didn't use the stock suspension but If your going to race the car you won't use it either. Good luck
Old 11-16-2002, 05:15 PM
Post
to tell you the truth we prob well use a stock suspension. and maybe a hotchkis kit.
Old 11-16-2002, 05:45 PM
Post
Good luck
Old 11-16-2002, 06:11 PM
Post
why do you say good luck??????
Old 11-16-2002, 06:15 PM
Post
Because if your motor develops any decent hp, stock suspension certainly won't hook up. Good Luck!
Old 11-16-2002, 06:34 PM
Post
[quote]Originally posted by fasttom5116:
<strong>Hi i am building a drag car it is an 84 camaro i need to know how wide (the length) of the camaro rear end and i am looking for a full list of what length 9" rear ends came in what.
Thanks!!
Tom</strong><hr></blockquote>
Here is a very informative site about 9 inch Fords.
http://hiqties.hypermart.net/9inch.html
As for the Camaro, you will have to crawl under it and measure it!!
Old 11-17-2002, 10:02 AM
Post
There are a ton of nine inch race part vendors out there. Unless you are only going to remove the air cleaner on your car and go do it, it would be a good thing to do a little checking on just what you need to do to make this swap work in your case. Bondsman is right on. I've often thought GM designed the entire rear of the car to break loose and smoke like mad so as to impress their target demographics, somewhere between 7 to 13 year old boys. .
