rear end housing bent? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2004, 02:04 PM
Question for the gurus:
I had my car by a chassis alignment shop yesterday. They told me that my p****enger side axle housing is bent. (the orig 12 bolt rear end). Its bent 3/8".
the guy told me that they straighten them "all the time" that are between 1/8 and 3/16 out.
Says he would know pretty quick if he could straighten it. If he could i would be looking at $450 or so.
Anyone car to comment on this prognosis.?
Is 3/8" too much? Should I be looking at replacement housings?
I know what they cost... ~$2k on average fully assembled down to $600 empty.
Just looking for some more knowledgeable opinions.
Thanks,
Roy
Old 03-18-2004, 03:28 PM
GTO 1965's Avatar
If the chassis guy is good he can fix the housing and you'll be just fine. I've straightened a few of them myself.
Make sure he is not going to charge you if he finds out he can't fix it though.
Jim
Old 03-21-2004, 11:04 PM
Pantaz's Avatar
Check out Currie Enterprises.
http://www.currieenterprises.com/htm...vyHousings.htm
Currie Enterprises, Inc.
1480 North Tustin Avenue
Anaheim, CA 92807
714-528-6957
Old 03-22-2004, 05:15 AM
Bent how? Camber wise?
Old 03-22-2004, 05:55 PM
Bent how?
The right side axle tube is bent 3/8" toward the back of the car. Causing a toe-out condition on the rear of the car.
Bad wreck in '90. Slapper bar hit a curb as the car was proceeding over a curbed median. Bent the trac-bar.
I've been driving the car like that since then. Never noticed it.
I only brought it to the chassis shop to have them diagnose a couple of other things that were driving me crazy.
Drivetrain vibe, front end slack etc... They told me the tailshaft my trans was pointing down (this is a custom crossmember sold to me by Bowtie Overdrives). They suggested I shim it up 1/4". Which I did. I replaced the rear u-joint too. Tightened the front wheel bearings to .005" endplay.
Told me I had a flat spot on my left front tire too.
Overall the visit to the shop was worthwhile as I was able to address 3 of the 5 problems they found in a few hours.
I guess new tires and either a new housing (ouch) or if I'm lucky they can bend mine back.
Thanks for all the replies.
Roy
