Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 05-30-2008, 10:24 AM
scrimshaw scrimshaw is offline
Rear end I.D.
Can someone help me ID this rear end. I am told it was off a Lincoln but year was unknown. WMS to WMS is 63.5". Bolt pattern is 5 on 5.
I need to shorten it by 2 inches. Axles are tapered so I am guessing will need new, but what about brakes. Are they easy to find/rebuild?
Thanks for any help.
Size:  196.9 KB  Click image for larger version
Size:  193.6 KB  Click image for larger version
Size:  188.8 KB  Click image for larger version
Size:  187.7 KB  Click image for larger version
Old 05-30-2008, 04:24 PM
Deuce Deuce is offline
CURMUDGEON / MODERATOR
 Deuce's barnstar
re: Rear end I.D.
Without the ID tag ... most everything is at best a educated guess ...
But I would guess a mid to late 70's Lincoln. They are not very desirable for most rodders because of the width. Also the wheel bolt pattern. Brake parts are expensive when you can find them.
Most of the time, it is more economical to just find a 9 inch Ford the width you need and add a disc brake kit to it.
Some of the late 60's Torinos and the 71 to 73 Mustangs were already in the width range you need ... from the factory. There are others also.
I went to the school of hard knocks ... where the tuition is high but the retention is exceptional !
Old 05-30-2008, 06:36 PM
re: Rear end I.D.
Thanks for the reply Deuce.
From what you say it seems like I would be better of just buying the whole thing from currie of moser? It's tough finding a decent junkyard around here let alone with any old mustangs or Torinos in it.
Old 05-30-2008, 06:45 PM
 Deuce's barnstar
re: Rear end I.D.
I sometimes forget that not everyone is blessed with a 80 acre ... in business since the 40's ... junk yard about 15 miles from their house.
Go here for more photos ...
http://www.jalopyjournal.com/forum/...ad.php?t=116005
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Rear end I.D."
68 Camaro Rear end Curtis Thornton Transmission - Rearend 14 03-12-2008 04:19 PM
Rear End - what to do?? 73Caprice Transmission - Rearend 2 01-04-2008 08:28 AM
where is the i.d. number at on a 80s model chevy van 8.5 rear end ? Mr. Wormy Transmission - Rearend 1 07-03-2006 04:27 PM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 12:44 PM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 05:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
