Rear end I.D. questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2012, 12:26 PM
I've recently found a rearend at a swap meet for $30. Good deal I'm assuming but I don't know what it is. So here's the describable features.
It has removable pinion carrier, and removable rear cover. Both are 10 bolt.
The pinion/drive flange is not a torque tube type.
Pinion carrier has an upper case K inside a triangle stamped onto the axle housing flange. The axle housing has H1936 stamped horizontally to the left of the rear cover. Also the axles are tapered and keyed for hubs.
Old 01-30-2012, 03:16 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Post a pics and maybe just maybe someone will know what it is.
Cole
Old 01-31-2012, 01:43 PM
https://dl-web.dropbox.com/get/Publi...jpg?w=e76f88d6
Old 01-31-2012, 03:38 PM
eloc431962's Avatar
Wiki Edits: 37
Link don't work.
Cole
hot rod rear end questions mahoo900 Transmission - Rearend 4 08-28-2011 10:37 AM
1st Gen Monte rear end questions itsa6 Hotrodding Basics 1 02-19-2011 10:26 AM
rear end questions MDot Transmission - Rearend 11 05-03-2009 09:12 AM
Rear End Questions 425HP Z28 Transmission - Rearend 6 11-05-2006 10:10 AM
8.8 rear questions mike bryan Transmission - Rearend 2 05-19-2003 03:38 AM
