rear end ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2008, 11:26 PM
rear end ID
need to I D the rear end that is in my 71 chevy C 20 4x4. May not be stock.Has one piece bridged housing.10 bolt round diferital cover
Old 06-24-2008, 11:42 PM
SSedan64's Avatar
I'm reasonably sure the 71's came with 12 Bolt rears. Someone may have swapped in an 8.5" 10 Bolt. Does the bottom of the center housing have a square looking lug on each side like the ones in the picture?
http://www.buickperformance.com/85rear.htm
Old 06-24-2008, 11:58 PM
rear end ID
No it does not.This is a one piece cast housing like a ford rear end but has removable dif cover
Old 06-25-2008, 12:00 AM
See if you can find it here: http://truckparts-specialists.com/ca...ture-guide.htm
Old 06-25-2008, 12:03 AM
SSedan64's Avatar
Do you mean it's like a 9" Ford rear that the center section comes out the front & has a removable rear cover?
Old 06-25-2008, 12:10 AM
rear end ID
yes it does look like a ford 9 inch with removable rear cover
Old 06-25-2008, 09:09 PM
rear end ID
looking to identify rear end, this is a removable carrier, has hard hat shaped rear cover that is removable.
This rear end looks like a Ford 9 inch.
This rear end has a 10 bolt pattern, with 2 bolts on each side towards axle shafts that are visibly closer together in pattern.
Un like Ford 9 inch, the only visible welds in housing are on top and bottom of dif. housing.
In axle housing taper from dif. to axle shaft bigger than Fords.
Old 06-26-2008, 06:53 AM
31 five window
Last journal entry: grill and rear end
Is it a 6 lug pattern? How about a pic? Sounds like it may be a 1957 type truck rear.
Narrowing a 9" ford rear end powerrodsmike Suspension - Brakes - Steering 6 05-05-2007 12:53 PM
Need help with my rear end chevy3600 Transmission - Rearend 3 05-04-2007 06:40 PM
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
