rear end ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2008, 09:24 PM
rear end ID
This rear end is out of 1971 Chevy C-20 4X4 Truck.
This rear end has a removable carrier, hard hat shaped rear cover that is removable.
Has a 10 bolt pattern, with 2 bolts on each side towards axle shafts are visibly closer in pattern.
This rear end is similar to a 9 inch Ford rear end.
Differences are the only weld seams in housing are on top and bottom of diff. housing.
There is a difference in the taper from diff. housing to axle shaft.
Narrowing a 9" ford rear end powerrodsmike Suspension - Brakes - Steering 6 05-05-2007 12:53 PM
Need help with my rear end chevy3600 Transmission - Rearend 3 05-04-2007 06:40 PM
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
