rear end id - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2013, 08:01 PM
rear end id
I just found a rear end for my mustang, I have in it now a 12 bolt with 538 gears, what i bought was a 1957 9in, but the numbers on the diff dont match ford online, i would apr, any knowlege ,Thanks Cliff from calif. the number is WAA 4668B, HOODED.
Old 01-26-2013, 08:18 PM
big gear head's Avatar
High Performance Rear Ends
You have a Chevy 12 bolt in a Mustang? That's different. The '57 9 inch would only have a tag with the gear ratio on it. There wouldn't be anything else on there. Must be later than '57.
The Following User Says Thank You to big gear head For This Useful Post:
Cliff Griffiths (01-26-2013)
Old 01-26-2013, 08:22 PM
thanks, for info, there is no tag on this rear end, only numbers on the diff, unit
Old 01-26-2013, 08:26 PM
And about that 12 bolt in my mustang, in the early 70s we used the 9in for racing and cheep 12 bolts for street rods,they bolt right in to mustangs of the 60s
Old 01-26-2013, 10:52 PM
Must be a first gen Camaro 12 bolt. I know several people who have bolted early Mustang 9 inch Fords in their first gen Camaros. Strange how things turn around. The price on those Camaro rear ends has gone through the roof.
Old 01-27-2013, 08:27 PM
ford 9 in
Idid not know that the 12 bolts are coming up in price, its been 30 years since i played with my mustang, i do want to install the 57 9in in just to have it all ford again, thanks Cliff
1953 Buick Special-front end rear end?? mbjeep Suspension - Brakes - Steering 8 12-06-2009 07:32 PM
stock 63 chevyII rear end vs. s-10 rear end david6chevy Transmission - Rearend 3 08-17-2009 05:36 AM
Gm 12 bolt truck rear end vs. car rear end '54 Pontiac Transmission - Rearend 6 02-05-2009 06:17 PM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 03:25 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 04:28 AM
