Rear End ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2005, 12:44 AM
Rear End ID
Need some help here guys. I have a 49 chev with a small block in it. Some years ago (before me) the original rear was replaced. I had a mechanic some years back tell me it was a 1958 vette rear (he replaced bearings). I am in the process of another rebuild of the car, and I was womdering how I could ID the rear, or atleast figure the rear gearing for tire size. The only numbers I could find tonight were on the driver side front of the rear end gear housing.
There is also a sheet metal tag that I could not read. The numbers cast on the front of the housing were K128 and below that was 3748888. I have been around the net, and cannot find a good sight to Id this rear. Does anyone know what it is or where I can go to ID it. I think it is of the 55-64 vintage GM sumthing.
Old 08-01-2005, 07:21 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Is there any way you could post a picture of it?
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 09:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
