Rear end ID - is it worth rebuilding? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2004, 10:38 AM
Just hauled in a Chrysler 9 1/4" and have a couple of questions.
It is approximately 58 1/2" from flange to flange. Width of spring perches center to center is approximately 47 1/4". It has disc brakes and a pinion snubber. Ratio undetermined but does have a type of sure grip or maybe a locker.
Any ideas as to what vehicle this came off of?
Is it worth rebuilding? It is currently locked up with a moderate amount of surface rust inside. Doesn't look like pitting has started yet.
What is the weight of this thing? Surely it weighs more than the good old 8 3/4" and maybe more than the Dana 60. It is HEAVY!
Thanks for any help you can give.
Old 06-14-2004, 01:16 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
It most likely came from a half ton truck, but could have also came in an early car application.
Here is a link explaining a LOT about it, and costs of new parts.
http://www.drivetrainsuperstores.com...e2.asp?axle=10
