Rear end identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2007, 12:06 AM
Trying to find a 8.5 GM coil spring rearend for a 1980 elcamino from inner backing plate to backing plate it's about 52". Where can I find A list of ID Numbers or how can I identify the 8.5?
Old 12-22-2007, 11:09 AM
Big Don's Avatar
Identify
Go to any car salvage parts supplier and he has a interchange book that will list any and all rear ends that will work for you.
Old 12-25-2007, 07:52 AM
RONNYinWAXHAW's Avatar
Last journal entry: And then this happened...
El Camino rear end
Have you checked the FAQ section at www.maliburacing.com? There's a ton of G-body info there.
Old 12-25-2007, 01:51 PM
http://www.oldsmobility.com/10bolt-tech.htm shows how to tell a 7.5" from a 8.5". Good luck, because the 8.5" for that car is rare and expensive.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Narrowing a 9" ford rear end powerrodsmike Suspension - Brakes - Steering 6 05-05-2007 12:53 PM
Rear end Identification jokar1 Transmission - Rearend 1 01-26-2007 10:07 PM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
Rear End Identification Blaster Transmission - Rearend 4 11-29-2005 05:06 PM
