Rear End Install Probs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2008, 09:00 AM
Since purchasing my truck last summer (1969 GMC 1/2 ton) the 12 bolt rear end was making noise when I let of the throttle (like jakes brakes). I diagnosed it to the pinion bearing, Which may have been wrong as there was no preload on the bearings as I could move the yoke back and forth when taking apart but I thought I would have a look anyway. This was last fall (I'm slow and the truck is a toy:metal
I changed the 2 bearings on the pinion side and installed a new crush collar with the same shim. When I put it back together I can't get any backlash after tightening the bearing caps on the differential. It is perfect before I tighten them but after it binds. Just in case I mixed up the end caps I tried it every possible way with the same results. I also found pinion gear tooth marks on the diff after putting it together indicating that the pinion may be too far back. But since I only put in one 32 thou shim in I can't see how it could go any further forward.
Any advice before I take the pinion out again and waste the crush collar? Any ditances I can check to verify correctness?
Old 08-24-2008, 05:56 PM
sedan delivery's Avatar
back lash
if you know that the pinion depth is correct ,you can move the carrier to the left by changing the carrier shims left for right. you may have got them mix up. if this doesnt work you will need a shim pack from the dealer.(side carrier sjim pack).measure the shim you have and make up shims to be less a few thousands for the left side and add the amount to the right side.. this will increase your back lash.. good luck.
Old 08-24-2008, 06:57 PM
It almost sounds like the original problem was the pinion nut came loose or the bearings were completly shot. If it has marks in the carrier that is the most logical cause.
What kind of rolling torque/bearnig preload do you have on the pinion now without the carrier installed?
What does the gear tooth contact area look like, can you post a picture?
68 Camaro Rear end Curtis Thornton Transmission - Rearend 14 03-12-2008 05:19 PM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
anyone running 700r4 with 3.55or 3.77 rear end? 37 chevy Transmission - Rearend 7 01-06-2003 06:34 AM
