rear end leaking oil??
So I have a rear end I bought off ebay. It was a freshly rebuilt never used piece a guy was parting out the car. Anyway the problem I have is a oil leak coming from what appears to be behind the pinion nut. Like between pinion nut ant yoke. Can I tighten this nut a little bit to get rid of the leak? I know there is something about a crush sleeve involved with this and I know I cant just reef on it. But i was thinking 1 more turn of the nut might do the trick. I just dont want to mess anything else up.
Leaks from oil migrating up the splines on the pinion are possible which is why most factory assemblies use a liquid sealant on the cavity under the nut, or under the washer if one is used. I use regular RTV, just dont ge it on the threads of the pinion if you want to use loctite. It is important to measure the prevailing pinion bearing preload and restore that amount, or mark the nut and the pinion carefully and simply retorque the nut to the same physical location.
Sounds like a pinion seal leaking replace the seal and it should stop leaking.JMO...Cole
Your going to (if you don't have a yoke holding tool) find a way to hold the yoke to get the nut off. As far as the preload on the pinion nut you can count how many turns the nut takes to come off and put the nut back on exactly the same amount of turns.
Vince |
My bad! shame on me. I need to read more and quit relying on memory.
No intention to steal the tread but, I've got some side play on my front axle pinion in my 4x4. I'm not sure if it's a dana 44 or a GM 10 bolt yet. I'm GUESSING it's got bearing problems. Would I be correct?
Thanks guys. The advice given is what I was thinking. How ever if for some reason I dont get the preload set correctly. What is the cause and effect?
There is a washer there and I was thinking of using the RTV sealant. My plan is to not count threads due to a thickness change in sealant. unless I can find a new seal here locally. My plan is to check what torque, nut is currently at by slowly increasing torque wrench until i get just to that point. Then duplicate upon reassembly. If all I have to do is go under washer then tightening to the yoke should'nt be bad. Thanks guys rear ends are my kryptonite lol . so I will nervously attempt to fix the leak my self. |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| Environmentally friendly honing fluid. | F-BIRD'88 | Engine | 16 | 07-01-2007 10:06 AM |
| Rear end no oil, big mistake. | anyoldchevy | Transmission - Rearend | 14 | 06-23-2007 09:28 PM |
| Narrowing a 9" ford rear end | powerrodsmike | Suspension - Brakes - Steering | 6 | 05-05-2007 12:53 PM |
| S-10/Camaro Rear End | slaveforthewave | Transmission - Rearend | 7 | 02-20-2006 01:44 PM |
