Rear End Lights On 57 Chevy Pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2011, 09:58 PM
NCC1701D's Avatar
GREGF
If I Have A 6 Wire External Turn Switch And A Six Wire O.e. Steering Column Can I Run The Rear Turn Signals To The Brake Lights On My Replacement Stop/turn/tail Lights? Or Do I Need Separate Turn Signal Lamps?
Old 04-17-2011, 01:15 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
See attached schematics of a typical turn signal/stop/tail light arrangement.
The TS/stop lamp is controlled through the TS switch.
Separate wires are needed for the right and the left side lamps.
vicrod
1954 Chevy 1/2 ton pickup brake lights latebloomer Electrical 4 06-12-2010 09:49 AM
rear suspension 40 chevy pickup 71corvette Hotrodding Basics 8 12-10-2008 10:34 PM
62 chevy pickup rear end carrier into Bel Air Tymer Transmission - Rearend 1 07-30-2008 09:14 PM
chevy pickup tail lights frank88chevy Electrical 3 01-23-2008 11:29 AM
1954 Chevy Pickup - Tail Lights horvath Electrical 6 02-25-2003 06:04 PM
