rear end on MGA - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2003, 10:01 PM
rear end on MGA
I bought all new parts for the rear suspension on my 1961 MGA. Problem now is that it rides high in the back and I can't get enough compression on the springs to attach the rebound strap. Anyone got any ideas?
Old 09-18-2003, 02:54 PM
UncleFluffy's Avatar
never returns tools
Couple of sandbags in the trunk plus some blocks under the rear wheels should do it ... but, even if you get the rebound straps attached, they shouldn't be under tension in normal driving conditions.
I know Bs better than As, but looking at the drawings of the rear suspension on the Moss site it looks like an almost identical setup.
The only advice I can give without getting under it is to check the strap length and spring curvature against the original specs (the Bentley book should have them) and send whichever bit is wrong back with a rude letter. It's possible someone sent you the wrong bits by mistake.
If both are right, then I'm completely out of ideas ...
