Rear End Number - GM - CA0424W2 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2003, 09:54 PM
I am trying to find out what the CA0424W2 number is on a rear end that I have. I am trying to find it's ratio and if it is a posi. It is a ten bolt. I want to put it in my '40 Ford. Does anyone have an opinion on what width of a read end to put in a '40 Ford? I have a 8 inch Ford rear end that is 49 inches wide. It will not let me put the rear sway bar on. So, I am looking at the CA0424W2 rear end, which is 54 inches wide.
Old 07-21-2003, 12:09 AM
Dozier768's Avatar
is it a gm 10 bolt?
Old 07-21-2003, 06:42 AM
Yes, it is a GM rear end.
Old 07-21-2003, 01:50 PM
Dozier768's Avatar
i did some searching around and i beleive its a 3.08 olds rearend with an open differential. heres where i found the axle decoder http://www.team67.com/groups/group.005/axlecodes.htm
