the rear end is odd - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2002, 02:22 PM
Post the rear end is odd
I have a rear end for my 63 falcon and I need to find out the size differential to put in. I think it was from a truck and cut to size. there is a small label that reads 7D1 and also D5AWB if that means anything. The gears load into the housing with the axles and there is an inspection cover facing the rear
[ September 01, 2002: Message edited by: FalconGuy ]
[ September 01, 2002: Message edited by: FalconGuy ]</p>
Old 09-01-2002, 02:35 PM
aka Duke of URL
Arrow
Do the gears load from the front or back? Does it have a rear inspection cover?
-8" or 9"-
Old 09-01-2002, 02:38 PM
Post
The gears come in from the front, and it has a cover on the back.
Old 09-01-2002, 04:56 PM
aka Duke of URL
Exclamation
AHA! You changed your post on me...
D5AW-B....Exactly where was this located...on an attached tag on the rear cover or on the axle housing itself?
Just from what you have given so far, it souds as the housing is from a mid-seventies LTD and is an 8.8 rear.
Any more i.d. on the housing? If it is a dana rear (light truck), there should be a series of numbers stamped on the rear of the right axle tube.
Old 09-01-2002, 08:50 PM
Post
The number is located on the front/bottom side of the gear housing, and there is no number visible on the right axle tube.
Old 09-01-2002, 11:02 PM
aka Duke of URL
Arrow
If there is a D5AW stamping on the center section, it would have to be a mid-seventies housing out of a Galaxy/LTD. There were only two styles then...9" and 8.7". Seeing as yours has a rear cover, it has to be the 8.7" (8.8") The 7.5" didn't appear until 1979.
Late Note: This style was also used on the Granada of that period. It is hard to ascertain from component I.D. nos. as these were used on more than one type of assembly and/or car line. If the assembly tag is missing, complete teardown may be necessary to properly identify the assembly.
This is just an educated guess with the information you have supplied mind 'ya...
[ September 02, 2002: Message edited by: KULTULZ ]</p>
Old 09-03-2002, 07:16 PM
Post
Thanks for the asiist, but it seems I found a good 8" to go in for cheap. Any suggestions on gear ratio would be appriciated.
[ September 03, 2002: Message edited by: FalconGuy ]</p>
Old 09-04-2002, 01:27 AM
aka Duke of URL
Arrow
Need to know engine type (and modifications), trans type and planned use (street-work-hiway).
