rear end out put yoke??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2007, 11:07 AM
I got the correct spline output yoke for the rear end. This is a chevy 8.5" rear. My question is i need the straps that hold the U joint in along with a U joint that has two of its ends bigger then the other two. Do they even make such a thing and if so where can i get these items from. I need new straps because my originals are too small.
Old 09-21-2007, 12:14 PM
Any parts store can sell you a strap kit. You need to know about what vehicle the rear is out off to get the correct one, but there is only about 4 for the 8.5, most being a Mechanics 3R. A cross u-joint is also a normal item but the normal parts store may have trouble looking it up unless you know the u-joints involved, like 3R to Spicer 1310 for example.
Old 09-21-2007, 08:59 PM
boatbob2
u-joints
im not really sure of what youre talking about,but SPEEDWAY.COM has joints,with chevy and ford sizes on the same joint.
Old 09-21-2007, 09:23 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Here is a link to the Neapco Automotive Universal joint Catalog ... in PDF format.
You will need to haveAdobe Acrobat Reader (free) in order to view it.
"Conversion Joints" is what you are looking for, and you'll find them on page 350.
The retaining straps are on the 2 pages preceeding the conversion joints (348, 349)
HTH,
Don
Old 09-21-2007, 09:50 PM
66GMC's Avatar
Just a note ... if this is indeed the correct conversion joint ...
"3R" is also known as "S44" (Saginaw)
... so the part number that I think you would want would be 3-3130 for the greasable one or 3-3130BF for the permanently lubricated "Brute Force".
Looking at that chart ... there appears to be a typo.
3-3130 shows (4) 1.125" OD caps
3-3130BF shows (2) 1.063" and (2) 1.125"
Now the straps ... depending on which set of caps fits on the diff:
if 1.063" caps (1310 series) ... use p/n 1-0022
if 1.125" caps (3R or S44 seies) ... use p/n 1-0025
HTH,
Don
Old 09-24-2007, 11:12 PM
I got both at a NAPA store when I changed mine out.
Old 09-25-2007, 12:33 AM
charger528's Avatar
Last journal entry: 1991 Mustang LX Mopar powered Drag car
mopar guys have the same problem when they change to after market gears. I got my ujoint at a speed shop it was a lakewood unit they listed a few different odd size combos with inside or outside clips .
good luck Bill
Old 09-25-2007, 07:37 AM
Thanks a bunch 66GMC Thats exactly what i needed. Believe it or not my combo was not listed so i called them and as it turns out i can swap the bearing caps to get the combo i need. My problem was the bearing dia to the length. They had the right dia but wrong lengths.
will a '69 Chevelle rear end fit into a '70 Chevelle? SMO'KUM UP Introduce Yourself 2 09-17-2007 08:15 AM
82-92 camaro posi rear end info NoEgoMan100 Transmission - Rearend 4 10-21-2005 03:22 PM
Rear End Change... Juicer Transmission - Rearend 0 10-07-2003 11:23 PM
Rear End Number - GM - CA0424W2 DAutoMan Transmission - Rearend 3 07-21-2003 02:50 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
