Rear end question on a 12 - bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2013, 05:54 PM
i have a question ....
29.5 size tire and its 80 lbs, its going into a re-built rear end truck , 12 bolt
question, do you think its better to stay with the original 3.42 or go to a 3.73 rear end?
i hardly use the 1978 chevy big ten truck for towing but every so often i'll use it for hauling etc...
also a single wheel is better for daily driving or is posi- really worth the upgrade for simple driving... the motor is a 383 and the trans is a 700r4....
a mechanic told me it puts more stress on my motor for it to turn 2 wheels than one
Old 05-15-2013, 07:34 PM
Banned
I'd stay with 3.42 gears as the 7004r has a low 1st gear..
your engine never sees any extra load from 2 tires putting power down.. over a single..
Old 05-15-2013, 09:22 PM
big gear head's Avatar
High Performance Rear Ends
Find another mechanic.
If you want to put all of your power to the ground then you need both tires pulling. Smoking one tire doesn't impress anyone. It just looks stupid.
The Following User Says Thank You to big gear head For This Useful Post:
demarques_191 (02-02-2014)
Old 05-17-2013, 11:50 PM
vinniekq2's Avatar
smoking one tire causes spider gears to try and escape out the back cover. the difference from 3.42 and 3.73 is not that much,not worth the change
The Following User Says Thank You to vinniekq2 For This Useful Post:
Old 05-23-2013, 07:44 AM
lmao!! ive seen some squeeky rear diffs caused by frying one tire off.
10 bolt rear end question 8.2 or 8.5 ?? nheron Transmission - Rearend 6 03-02-2008 09:16 PM
10 bolt chevy rear end question powerrodsmike Transmission - Rearend 3 09-15-2007 11:00 PM
10 bolt rear end question 8.2 or 8.5 ?? nheron Introduce Yourself 1 09-14-2004 10:26 PM
12 bolt rear end question Roy_67_SS350 Transmission - Rearend 3 01-04-2004 07:12 AM
Question about 12 bolt rear end Roy_67_SS350 Transmission - Rearend 6 12-14-2003 12:57 PM
