Rear End Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2009, 11:41 AM
Rear End Question
what would be a good rearend for an 87 s10 to hold up to a 350ci motor please note its a 5 speed and it mite get dumped on a couple times
Old 04-06-2009, 11:56 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
It all depends on what you are going to be doing with your ride.how much HP you have /tire size/.things like that we need to know to truly help. cole
Old 04-06-2009, 12:01 PM
stock with some head work and a 500lift 264 duration which is an advance dur of 305 carbed with possible eldebrock performer intake and a 600 carb
Old 04-06-2009, 12:07 PM
eloc431962's Avatar
Wiki Edits: 37
are you running the stock rearend now and really need what tire size you are going to be running also.are going to be running street tires or dot street slick? cole
Old 04-06-2009, 12:11 PM
DaSouthWon's Avatar
I put up the tools against$300
try a dana 60, that oughta cover it
Old 04-06-2009, 12:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Is the cam .500" lift with 264 degrees duration @ 0.050" and an advertised duration of 305 degrees?
Old 04-06-2009, 01:38 PM
fast68's Avatar
likes chevy trucks & boobies
Old 04-06-2009, 03:28 PM
techinspector1's Avatar
Wiki Edits: 326
Son, you are in for a rude awakening.
Old 04-06-2009, 03:35 PM
life is a temporary assignment
Don't cut any corners.. Put a 9'' in it and be done,You will add more hp later.It alway happens.
Old 04-06-2009, 03:44 PM
eloc431962's Avatar
Wiki Edits: 37
very nicely put. NEW INTERIORS.i must agree. cole
Old 04-07-2009, 07:20 AM
what about the mustang 8.8 anyone ever tried this i got one with moser axels that should hold up to a decent horsepower shoudnt it
Old 04-07-2009, 08:24 AM
DaSouthWon's Avatar
The 8.8 is a good axle as "fast68" suggested. They are a dime or dozen at pull-a-part coming on everything from Crown Vics and Mustangs on up to the pickups. If you know how to weld and have a pneumatic die grinder you can probably find one close enough width wise to fit your purpose. If your looking for cheap I think it's a good route to go. The strength of the axles can usually be determined by their spline count. Fox body Mustangs came with 4 lug 28 spline axles. Moser makes them in 28, 31, 35 and I'm sure other sizes in 4 and 5 lug configuration. It's pretty close to impossible to snap a 35 spline axle on the street with radials unless they're 2 feet wide.
Old 04-07-2009, 09:19 AM
302 Z28's Avatar
Ford 9" got to be one of the most cost effective swaps in the history of rodding. There everywhere and cheap.
Vince
Old 04-07-2009, 09:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Nah, TI- it's a baby cam. Told me so hisself. lol
Old 04-07-2009, 11:23 AM
why yall say im in for a rude awakening with the cam i have
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 10:03 AM
T-Bird rear End Question Dave57210 Transmission - Rearend 5 03-21-2007 09:31 PM
NASCAR style quick change rear end question Jeeper426 Transmission - Rearend 3 06-21-2006 05:24 PM
91 gm 7.625 rear end question???? camaro420 Transmission - Rearend 2 05-01-2006 09:22 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
