Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear end questions
Old 11-14-2012, 07:26 AM
delawarebill's Avatar
delawarebill delawarebill is offline
cheaper gear change...
what rear r u running now ??? and do u know the gear ratio also. if not jack up the rear, mark the d-shaft and tire and then rotate the tire counting the turns on the shaft.. u'll be close without pulling the rear apart.. if your in the 4's then move to a higher gear (lower number) in the low 3's...
