Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rear End Questions
Old 11-01-2006, 08:43 PM
Lonestar's Avatar
Lonestar Lonestar is offline
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Originally Posted by Vortech 4.3
sounds just like differencial bearings to me. if it was an axle bearing, the noise would even be there in neutral.
Yes, it does sound like a loading issue...when load is applied (car in gear) the howl is there, but when load is not applied (coasting in neutral) it goes away.
A wheel bearing does not act this way, but the diff gears do.
Sound does travel in weird ways, so even if it seems like it is coming from one side it may not be so.
Who set up the rear end?
